Автор Тема: продам видеорегистратор  (Прочитано 3428 раз)
Оффлайн VITO
продам видеорегистратор (новый) 4000 руб. 89025614550
« Последнее редактирование: 02:33, 25.05.2011 от VITO »
Оффлайн lahmatiy07
  • lahmatiy ROTMAX
Re: продам видеорегистратор
« Ответ #1 : 16:46, 04.04.2011 »
марка
или характер-и
Туда где грязи много!
Оффлайн VITO
« Ответ #2 : 16:58, 04.04.2011 »
Appriciated for chosing the CDV600 series high clear digit vehicle to carry the phantom recording instrument. This product is not only the model of specially product which nowadays the auto accident collects evidence difficultly to research, but also satisfies in the market other situation use demand, can let you one machine multipurpose, lets your life without cause for grief, colorful.
This product has the profession leading DV, save voice, network camera. TV functions and so on synchronization output, voice control video recording. This product has the original user-friendly design: Exquisite, fine, unifies the multi-purpose supports to be able to let the use be more widespread, suits the council book, the monitoring evidence collection, the outdoor scene photography, the evidence collection photograph and so on.
Configuration
Pixel: 8.0 Mega pixels CMOS
Smallest degree of illumination: 1Lux
Battery capacity: 1200maH
Continually video recording time: >5h
Power loss: 130ma / 3.7V ( Max )
Memory temperature: -10~70
Operating temperature: -10~60
Memory Card: SD Card
Memory: 1GB--32GB(the memory card is not included).
Video recording form: The video frequency decoding uses Motion, JPEG to record AVI document format VGA the 640*480 @ 20 / 30 f/s
USB connection: Mini5Pin USB 1.1/2.0
Operating system: Common PC
Memory consumption: 1GB / about 35min
Duration of charging: About 5 hours
Оффлайн Бандера
  • БуцефаЛ
  • летим летим
« Ответ #3 : 19:01, 04.04.2011 »
а на родном языке слабо...
Оффлайн Бандера
  • БуцефаЛ
  • летим летим
« Ответ #4 : 19:04, 04.04.2011 »
это автомобильный цифровой видеорегистратор без монитора 640x480@30 fps с возможностью записи по движению (модель CDV600). Данный авторегистратор относится к линейке бюджетных авто видеорегистраторов и при этом имеет потрясающе низкую стоимость - менее 100 долларов. Но тем не менее он имеет достойные технические характеристики и хорошее качество видеосьёмки, он способен снимать цифровое видео на SD карту памяти с разрешением 640х480 пикселей и скоростью 30 кадров/сек а так же имеею функцию записи по движению. Этот автовидеорегистратор станет Вашим верным помощником при любой дорожной ситуации, будь то ДТП, развор с сотрудниками ГАИ или просто съёмка пути по которому вы ехали. Данный автомобильный регистратор  к сожалению не обладает дисплеем для моментального отображения снимаемой сцены, но компенсирует этот небольшой недостаток хорошим качествомвидеозаписи со звуком, а просматривать записанное видео  можно после того как оно было записано (например дома или же на ноутбуке).
      Пользоваться этим автомобильным видеорегистратором очень просто - Вы вставляете в него SD карту памяти, крепите на лобовое стекло автомобиля с помощью присоски, идущей в комплекте и включаете шнур питания в автомобильный прикуриватель. Дальше сьёмка происходит в полностью автоматическом режиме, т.е. когда Вы заводите автомобиль - то сьёмка автоматически начинается, а когда глушите - то авторегистратор автоматически сохраняет видеофайл и выключается. Когда SD карта памяти заполняется - автоматически начинается перезапись наиболее старых видеофайлов.
        Так же данный автомобильный цифровой видеорегистратор может быть запитан от электрической сети в домашних условиях и записывать некоторые радостные моменты в Вашей жизни. Особенности:
  • элегантный и эргономичный внешний вид без проблем впишется в салон любого автомобиля;
  • простота в установке;
  • возможность переноса записей на ПК с легкостью;
  • отличное качество съемки видео и записи звука;
  • хорошее качество записи при низком уровне освещения;
  • цифровая 3 мегапиксельная камера;
  • разрешение видео: VGA 640*480@30 fps;
  • сменная литиевая батарея 1200 mAh;
  • поддержка расширения памяти картами типа SD до 32Gb;
  • возможность активации записи по детекции движения;
Спецификация:
  • матрица: 3.0 мега пикселей CMOS;
  • угол обзора: 72°;
  • минимальное освещение: 1 Lux;
  • сменная батарея: 1200 mАh;
  • непрерывное время записи: до 10 часов;
  • потребление: 130ma / 3.7V (макс)
  • температура хранения: -10°С ~ +70°С;
  • рабочая температура: -10°С ~ +60°С;
  • совместимые карты памяти: SD-карты;
  • мксимальный размер памяти: 32 Гб;
  • формат видеозаписи: AVI файл VGA 640*480@30 fрs;
  • порты: USB 1.1/2.0
  • операционная система: любая семейства Windows;
  • размер записи: 1 Гб памяти = 35 минут видеозаписи;
  • продолжительность полкой зарядки: 5 часов;
« Ответ #5 : 22:07, 04.04.2011 »
... при этом имеет потрясающе низкую стоимость - менее 100 долларов.
За 70 баксов, забираю :)
Оффлайн kamaz jr
« Ответ #6 : 23:08, 04.04.2011 »
а как понять что он снимает, если дисплея нет? интерес не праздный.
Оффлайн VITO
« Ответ #7 : 02:00, 05.04.2011 »
Миша я за него отдал 3500, брал для жены, но ей не понравилось, что нет экрана... поэтому и продаю (когда брал думал что все регистраторы с экраном...)
у меня регистратор с экраном, однако почти всегда экран сложен... экран то нужен по сути чтобы правильно установить "глаз", но у этого регистратора есть видеовыход и его можно подключить к любому монитору, либо настроить с помощью ноутбука...
Оффлайн VITO
« Ответ #8 : 15:30, 06.04.2011 »
возможен обмен на чего нибудь
Оффлайн Pill-ot
  • /Ай лав май Крузер/
« Ответ #9 : 15:51, 06.04.2011 »
А где брал????
Может в Иркутске есть где подобные девайсы, но с дисплеями.
ТLC LJ72/Super Swamper Bogger  33-12.5/ IRON MAN 2"/лебедка ручная"дву педальная")/шноркель\ силовые обвесы/зад -diff lock/
Оффлайн VITO
« Ответ #10 : 19:54, 06.04.2011 »
заказывал с Китая
Оффлайн VITO
« Ответ #11 : 18:58, 09.04.2011 »
ещё один появился...
« Последнее редактирование: 02:34, 25.05.2011 от VITO »
